I had the tech remagnetize the Alnicos. He said that they didn't need it (kind of an overblown problem, as long as you aren't dropping the speakers). He charged $100 to do 4 136A and one pair of 122A.
That was then ! Mr. B
Now the only place in the US doing Re-mags is in Cali, that I know of.
When asked of Mr.Greg Timbers, JBL designer engineer JBL Alnico' 15's
Do loose magnetic strength when overheated, Over-powered, or dropped.
He did say the old style LE15-2215's are not effected,
due to their Extremely underhung
voice coil.
I used 200 Watts as a Low #. I regularly used to push my 136's and 2231's Hard
with a crown Power line 4. rated at 185 watts but tested by Crown at 256 watts rms.
No damage or loss of strength.
Music sources are peaky, and generally not continuous.
So No over heating in a normal Domestic situation.
Home theater with Massive special effects, is a different thing entirely.
Before I got my latest 4435 monsters i used a pair of Alon Thunderbolt subs.
Aprox 4-500 watts each. single 12".
When watching a Heavy Action film at Crazy levels, their heat sinks were extremely HOT.
sometimes going into protection mode.
We're trying to help Onebean build a Sub.
I doubt he's going to buy a vintage pair of Alnico drivers.
On the size JBL recommends and uses;
the L-200's L-300's, 4367's 4430's are listed at 5 cu ft. by the time you figure in damping material,
Crossovers, structural supports, drivers and horns, ports,
they are closer to 4 cu ft.
BTW I am a Huge fan of Alnico drivers.
There are NO dedicated NEW Subwoofers using them.
Not counting the $$$ JBL AL1500's
