Descartridge
Stereos been berry, berry good to me!
This may prove to be my most ambitious undertaking, a Michell GYRO Dec. Please let me know a source of parts and if you have any advice.
Thanks
- The Motor spindle is floating, not fixed in place. I do not know if this is intentional design. The issue has been solved.
- The three spring adjusting supports are not functioning. That is, the aluminum sub chassis is not suspended above the acrylic plinth. The issue has been solved.
- The protruding brass weights attached to the platter's bottom- touch the aluminum sub chassis. I need to check and see if the bearing is missing or do I simply replenish oil?The solution in in-progress.
- One of the three feet is missing. I thought the stud was of metric threading; but a tryout proved incorrect. A new foot will be machined.
- The caps covering the spring assemblies are missing. Caps will be fabricated.
- The power supply is absent. I will probably build one. A hopeless case- a new motor is on order.
- A Magnepan Unitrac tonearm is mounted; but the counterweight and the rod attached to the cwt are gone. I have a WTB ad on BT related thereto.
Thanks
