hello kevzep! Thank you for your assistance in my problem. I am originally from Guam and but now retired in Vietnam. When I take the measurement at Pins 43,45,46, my readings are : pin 43= -.2dc and 20v ac, pin 45=0 dc and pin 20v ac, pin 46= -.1 dc and 10v ac and pin 48 0 volts dc and 10v ac. I replace the respective bridges related to the above pins but the issue still persist. I do not have a scope to measure on those pins, just my old fluke 83.Its really strange since all it is the DC supply and its filters, simple and straight forward, but I have never seen anything like this. Thank you again kevzep for your help in this matter.
Have those capacitors on the output of those bridge rectifiers been replaced? Can you remove and measure them?
The only way that much AC can make it through there is for there to be a problem with the bridge, or the caps have to be completely shorted out? But then you wouldn't see that much voltage.
Are you sure the meter is not playing tricks on on you?
Also, disconnect the Pin 44,45,46,47,48 from the regulated supply board to eliminate anything on there which may be affecting the supply voltages.
When you measure again, measure Pin 44 to 43, then Pin 44 to 45.
Then, Pin 47 to 46, and then Pin 47 to 48.
See what you get then.
Also if there is no improvement, I would remove C 09, 10, 11, 12 and see how this affects the readings.
Adding to that, there are a number of components on the F-2778 board which are problematic, fusible resistors, some diodes, they are either MV12, VD1212, these are incredibly unreliable and need to be replaced.
Also, on the two AU-X1's I restored, there was a lot of corrosive glue on the F-2778 board.
These are things to address sooner rather than later.
