jaaronb
i posted this in the Mac forum, but crickets over there so far, so thought I’d post it here. I can delete the original if there’s an issue with duplicates.
I picked up a couple of MC30s from separate sellers over the past week and can’t wait to get them up and running.
They’re as close in serial # as I was able to get given my complete lack of patience - 19470 and 20477 - both using the 150/152b trannies.
First order of business will be rebuilding the power supply and bias sections. The kits that Yves of Vintage Vacuum Audio sells for these first steps should be arriving today. (I was impressed with how responsive, helpful and nice Yves was during our quick exchange).
Both of the amps power up and make sound, as their sellers assured me they would. They sound great, in fact, but I only played them for a minute or so to look for immediate issues.
Tube complement for each is RCA 6L6GCs, original 5U4GBs, and a mix of small tubes from my own stash I know to be good - Raytheon (Baldwin) 12AX7, Sylvania Gold Pin 12AU7, and RCA (Hammond) 12BH7A.
So far, I’ve cleaned them up cosmetically and deoxed the tube sockets.
Amp #2 (20477) has no issues so far - I believe it had a cursory going over before I acquired it. The voltages I’ve measured so (not all) far are spot on.
Amp #1 (19470) has an issue. It wants to begin to red plate the output tubes within 5 minutes of startup. A cursory measurement of voltages on the output tubes gives me this:
V5
407 vdc - plate
410 vdc - screen grid
-35 vdc bias - control grid
V6
414vdc - plate
411vdc - screen grid
-37 vdc bias - control grid
I did change the tubes out on the #2 amp and the issue remains.
Plates are not bright red, but definitely getting some color on the bottom half of the plates after a few minutes.
The tube sockets in #2 did seem loose - the rectifier in particular. I have tightened the rectifier sockets a bit with a tiny flat head screw driver. It holds a little better when you pull with force, but can still easily be moved side to side.
Measurements were taken after I tightened the rectifier sockets.
I understand the red plating can be caused by poor contact of one of the 12ax7s (among other things), but I have no idea what implement to use to tighten the small tube sockets. I could barely get into the rectifier sockets with a tiny jewelers flathead.
My questions are:
Given those measurements, any guesses what the culprit might be?
What are the most crucial next voltages for me to measure - or should I wait until I’ve gone through the power supply and bias sections before taking additional measurements?
Anyone have tips on how to go about tightening the small sockets?
Finally, I’ll be rebuilding the power supply and bias in the next few days - are those changes likely to impact the issue I’m having?
If not, which other caps/resistors should I be looking at as possible failure points?
Thanks in advance for any and all assistance, tips, encouragement you folks care to provide. I’ve already gathered a ton of great information here.
V5
407 vdc - plate
V6
414vdc - plate
My questions are:
