No, fused side hot.
I fuse the hot leg.
Just to confirm, are you grounding pin 2 of the 5U4GB when measuring this ? The manual says that one requires the jumper for measurement. Without it, I'd expect somewhere about 780K to ground.
must have an open resistor or connection somewhere around the 12au7 if its reading that high. How both would end up the same is very strange but the schematic says it should be a lot closer to the 2.5K they call for vs the 3M you're seeing.
unless the schematic is not accurate.
