Mauricio719
Good evening, the left channel of my Sansui 719 died, it does not emit any sound through the speaker or through the left headphones, I can get stereo sound from the tape jacks to the computer; disassemble and check the fuses, all marked correctly; also check the rectifier (without disassembling) and frame well; when I try to check the transistors (without disassembling) apparently they all behave the same, I didn't find any anomalies there.
This was due to an accident I had connecting a second turntable, the speakers were getting a lot of noise from the phono input so I turned the volume down to check for ground, when I thought it was ok I turned the volume up to about 80%, in At that moment I think that a cable making a bad contact generated a noise that put the amplifier in protection mode, I turned it off and on but the left channel was gone.
I have been following you for more than 15 years, I have supported myself in learning about audio and in this case to make the first revisions, there are still many things that I do not understand about electronics but at least I want to review it as far as I can.
look for burns or filters with bad appearance but I did not find, I share some photos.
Thank you
Thank you
