I understand, I don't believe in luck so the way is to read and try as much as you understand. What you have told me has been very helpful and even though I have not followed your instructions to the bottom, I am going to do the task without any hassle. Thanks!
Good to hear you were not discouraged by my message!
I can understand it may have sound a little harsh, good you didn't take it that way.
It was meant as a reality check.
I can recommend the tutorial mentioned by hypocrites from Conrad's site.
Read it several times. It will give you insight in the process. Most important point he makes: "troubleshooting is done mostly with the mind, not with the soldering iron!"
My first amplifier that I repaired/ restored was an AU-719. I managed to do this with the help of some members of Audiokarma, but even more by reading a lot of threads on here about restoring, learning from books and other internet sites like Elliot sound.au what are the basics of a audio amplifier circuit, its powersupply and the components. This happened before I started but also during the process.
Here is the schematic of the control amplifier.
The top part with the transistors contains most switches and the volume potentiometer and the amplification circuit for when the tone control switch is on ( S3 ). When you look at S3 you can see that is drawn at both sides of the amplification circuit. The position numbered 1 is connected from both sides with a line. This means when the tone control switch is in 'off' position the amplification circuit is bypassed. This means that when you use the aux or tuner input terminals the signal only will go through some switches and potentiometers and it will not even depend on the regulated powersupply.
Then a picture of the powersupplies.
Physically this is located on the same board as the protection circuit. ( Remember, schematic is what it name implies, not a direct representation of the real world, but a schematic, so we can see the flow and identify components in that flow easily).
The part with Nr 1 is the regulated powersupply which provides power for the equiliser board and the tone control board.
The part with Nr2 is the powersupply for the driver boards and the output transistors. Realize that part of this is wired point to point ( the main filter capacitors) and part of it is on the board ( rectifiers, fuses).
Then the driver boards.
I circled the connections to/ from this board. Red are the powersupply / ground connections, blue the signal connections. The numbers you can find on the boards to, the letters are to find the connection to other boards/ locations in the schematic.
Download the service manual from Hifi engine or AK digital doc and study this. This way you can find them in your amplifier ( without power on).
When you start to feel comfortable with finding connections on the boards you can start measuring voltages. You can compare voltages between both channels. Don't go measuring without knowing what you will expect at that location, no use for that.
Be sure you understand what measuring voltage means and how to do it.
Good luck.
