Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Never suggested to purchase. Thought he already had said sub. Not ill advised if were for experimental purposes. Not my first time around the block. Been doing this over 40 years now.
Thanks for the pic. You have two amplifiers in that unit. One runs the front speakers at 60wpc and this will accept a 4Ω load, like two pair of 8Ohm speakers or a pair or 4 ohm speakers. The Remote speakers are run by a separate 12wpc amplifier and you need to remote to change the volume of this output. It is not associated with the Front speaker main volume control on the front panel. Odd but that is how Onkyo used the extra computing power of the chip in that unit. But you can listen to a different source on the remote speakers. So hook them up somewhere else in the house and play some FM or stream to that second set of speakers. Use your main speakers for your regular listening.
