cmayo
Member
I have a very limited experience/knowledge of soldering, and need to replace the soldered-in tweeter protection lamps on some old DCM crossovers. I went with the Sylvania 211-2 lamp since it was easily available and was recommended in other threads, and I thought the wire clips on each end would be easier to solder to than the shiny silver caps. I was mistaken.
I've tried scrubbing the cap with [rubbing] alcohol, using a wire brush and sandpaper to rough up the surface and the best I've managed so far is to smear a bit of hot solder across the parts and let it form a weak cold joint; the solder just will absolutely not jump to the lamp, seems like no matter how hot I try to get it with the iron. I've tried leaded and lead-free rosin-core solder with similar failed results, paste flux anbd no flux (no improvement) and I've tried a small chisel-tip and a larger knife-tip on my soldering iron. The iron's temp setting is 350c.
I'm obviously doing everything wrong... what should I be using (solder/flux/temp/tip) and what might be the right way to do this? Any help would be much appreciated.
