ecluser
Would the wiring be like this? Bridge all three bulbs, then wire the bridge to the circuit board?
Yes
Or if I'm using the Ohms law calculator correctly, I'd need a 17W bulb to get the resistance to 8.6 Ohms, is that right? Should I actually look for a 17W 12V bulb? Or is there a specific bulb that folks are using in the TF600 and CX27?
Yes, 12V, 1.4A is a 12V,17W bulb. It's just two different ways to say the same. I don't know what they are using in the original cross-over. The spec (12V, 1.4A) is from you, in your post #18.
