SDup
I was listening to a record on Friday when the audio decreased suddenly. I checked my setup (description below) and I noticed that the left channel was dead. When I use balance to isolate it I get a hum (loudness increasing with volume) and when I turn the volume up to at least 50% I can hear very faint music in background. Right channel is perfectly fine.
Here is what I tried to locate the problem (after looking at several AK posts):
- Different input (AUX, FM) = both channel work (so the problem is not with the speakers)
- Reverse the RCA cables = the dead channel (and hum) switch to the right (so the problem is not the phono stage but maybe the RCA cables?)
- Disconnect / reconnect the cartridge and clean the headshell pins with Q-Tip + alcohol = no luck.
- Remove and reinsert the stylus = no luck.
So I suspect the culprit to be the left channel RCA cable? Unfortunately the RCA cables are fixed on my turntable. I also doesn't have another cartridge to try out.
Should I have my turntable looked at by a profesionnal? Is there any other steps I can take?
Any help will be greatly appreciated, I saw so many problems get fixed on this forum, I hope this one can be one of them!
SETUP
- Mitsubishi DP-EC8 turntable
- Sansui 551 amplifier
- Ortofon SuperOm 20 cart
SETUP
