Seth Wolpert
Hello all. Is there anyone there who knows this receiver? I'm trying to repair the power output stage. One channel is blowing fuses. Both output transistors tested bad and I replaced them, but the problem persists. Since then, I have replaced the other three transistors and all of the electrolytic capacitors. Still no luck. All
transistors I installed tested good.
My approach to the repair is to run the main power through a variac and gradually turn up the voltage until I
see current draw through the fuse fitting approaching about a half an amp. The working channel is only
drawing a few milliamps at that point. I'm then probing all of the DC bias points, comparing the working to
the non-working channel. Only one circuit node is showing any difference-about one volt. Is the use of a
variac like this a sound approach?
I've tried adjusted the bias. The current draw changes, but is still way higher than the working channel.
This thing is kicking my butt. Any help would be highly appreciated.
