Hi,
I am not sure this is the best place to ask for your help with a couple of questions. So, please let me know if I should post this in a different sub forum.
It is about how ground is managed in Japan, because I have a SET amplifier from Japan. I bought a 100V DIY Japanese dual mono SET amplifier that has a couple of 717As per channel driving either a 300B, 2A3, or a 45. The amplifier has fixed bias, hum pots, and a knob to select the operating point for either a 300B, 2A3 or 45 tube. The amplifier has two IECs in the back, one for each channel and each IEC has 3 prongs.
You can see all that in the pictures attached. Unfortunately, I do not have the schematics of the amplifier.
I am going to use the amplifier in the United States. Surely, the amplifier, being made in Japan, works with 100V and either 50hz or 60hz. The power transformers are Sansui P- 44B which I believe can work either with 50hz or 60hz. So, HZ should not be an issue.
These are my questions:
1. For the voltage and ground issue, I am planning to use this step down transformer, which has 2 outlets for 100V, in 1600 Watts, which should be more than enough even with the 300Bs in place. But, I am a bit confused with the ground issue. Clearly the IECs in the amplifier have 3 prongs, and the IEC outlet in the step down transformer linked above, has also 3 prongs. So, I was planning to simply use a common USA power cord from the IEC in the amplifier to the step down transformer outlet, is that OK to safely handle the ground or am I missing something? I am not sure how the ground is handle in the amplifier, but maybe someone can understand that by looking at one of the pictures attached that shows the wiring.
2. The amplifier also has 2 hum pots. Regarding the hum pots, I was planning to do what I usually do which is: Let the amp warm up for at least 30 sec without music, turn the hum pots clockwise until I hear the hum increase. Then turn counter-clockwise until the hum decreases and then increases again to about the level
where I stopped the clockwise rotation. And then, set the pot to the middle of these two positions. Is that OK or am I missing something?
Any help is greatly welcome.
Thanks in advance!
Alan
Thanks in advance!
Alan
