Help with identification of Fisher Amplifiers
qogApS*2%HhV
Can someone please help me ID's these?
I was told the are Fisher but there's no identification on them
For bonus points, what's the process to set the bias correctly?
Thank you in advance!
Tube and transformer layout look like a Fisher 80AZ, but the controls on the end aren't the same and it is missing the Fisher plate on the back and the screen over the tube section. Maybe a Fisher clone or some other model?
If you search for Fisher 80AZ pictures there are at least 4 variations.
This makes it 5. As I remember it uses a cathode feedback output transformer.
Sound is very much like a Marantz 8b.
Also they run super hot~~~!
Thank you. I apologizes for the rookie questions. I've never seen these before. My searching has come up fruitless.
a few questions:
1. What is this "Bias Pot" for? (There's no mention of it in the literature, I've read)
2. What is the toggle switch on the front for?
3. Any advice/thoughts?
Again, I appreciate the thoughts, guidance and insight.
.. look like a Fisher 80AZ, but the controls on the end aren't the same and it is missing the Fisher plate on the back and the screen over the tube section. Maybe a Fisher clone or some other model?
If you search for Fisher 80AZ pictures there are at least 4 variations...This makes it 5.
A modified 80AZ?
The what I'm assuming is a power switch is not original the rest looks original on what I can see on the front
other then a newish looking knob on the Level Adjustment
Any chance you could remove the bottom and take a picture where the orange and black wires connect.
Are these yours? They look original down to dust and factory supplied Mullard output tubes. They were model 80AZ and later model 100.
The pot on top is R2 in the circuit diagram. It’s the phase inverter balance adjustment, best left alone.IMG_0011.jpegIMG_0010.jpeg
Yes, they're mine. I acquired them yesterday. I'm apprehensive to take the bottom off. They're sounding wonderful. I've spent time with them this morning: Here's where I'm at: The on board "pot switch" - the one I'd associate with being a bias switch (R2). Is impacting loudness - in particular bring up bass levels. The front toggle switch - seems to function as the "loudness countour" on my other Fisher gear. I'm tweaking and turning until the sound is "diale'd in" - and they do sound wonderful. I wish I had some more framework to go on as I'd hate to do something wrong but in the absence of info. I'm playing. They came out of a mind-blowing collection of gear. They very well might be something special but at this point I'm not sure.
They are very special. Some would kill for an unmolested pair of those amps. The output tube are worth very serious coin.
Maybe reread the first line in the little box of post 9. The adjustment is critical. It’s not a tone control. Don’t jeopardize those 60+ year old Mullards.
Unfortunately the search function is down. Plenty of info there.
Someone has been in there. The square rectangular resistors are new. The large cap and the other caps appear original. One small blue cap looks new.
Pay attention to your fingers in there!
Thank you! Do you have any other thoughts/suggestions feedback? Keep 'em or pass them along?
Understand this. You’re one lucky guy to get these. Don’t know what you paid but you’ll not see a pair again anytime soon.
If you knowledge of all things tubes is limited I’d suggest you bone up. If not become a subscriber here on AK and pass them on to a member.
Thank you. 40+ years in. I know that I don't know anything.
The frustrating/disappointing part is I do not have to tools or skills capability to set the phase inverter. I'm out here on an island searching and watching videos and I'm simply from a different generation.
Thank you, again.
@DOBIEGUY
Can you comment on if the functionality of the "Constant Power" & "Peak Watts" was eliminated, bypassed or modified to work with the switch on the OP's units?
@Dswankey
My model 100 has only the Z-Matic pot in the front. It clicks to off when rotated fully CCW.
Considering someone was in there I won’t guess what’s going on with that toggle switch.
The Fisher illuminati will have the answers when they chime in.
These are great power amps. I've worked on 4 or 5. If it works I'd enjoy it.
