jFF_Bulbo
hello AK'ers.
I´m working on 2245.
on P750 power amps, i recapped both boards. DBT pass ok
on both unit i´ve changed all electrolitic caps.
BIAS is imposible to set properly on both channels. h756/h757 are extremely hot on both. When i blow on to the board, bias downs for a while, after few seconds bias start to climb again.
on the left i´ve changed h754/755 (2sc735) and h766/766 (2sa562)with 2n3904/2n3906. h753 replaced with new 2sc945. h760 now is a MJE243g. no bias good response anyway.
can anyone helpme to stabilish the temperature on the transistors?
thank you in advance.
right amp photo, not new h760 or h754-765 yet.......
