Help with repair on Sherwood s-2750cp
rickwhite4
I picked up this receiver at an estate sale and the left channel doesn’t work. The switches also don’t seem to make a good connection.
Any ideas on repair would be appreciated.
Hi Rick. Looking at your post count, I was about to welcome you to AK. Turns out you've been a member longer than me!
First off, clean all switches until the contact issues are gone. Check fuse F604 with a meter; visual inspection can miss fuses that are blown when the element separates in the end caps.
Thanks Ray. I plan to clean the switches up with deoxit. I was actually able to get both channels working by playing with the switch to disable the equalizer. I’ll also check the fuse you suggested.
If both channels when playing with the EQ switch then there's no reason to check the fuse.
