Dannyx
Good day folks. I'm new here so hopefully I'm doing everything right and can get some help with this amp I'm trying to fix. I like to give plenty of details, so please bare with my long messages, since there's a lot to discuss.
So: it's a Technics SU-V550 - fairly old stuff - but the price was very low when I got it and it worked....to a degree. By that I mean it sounded fine in the left channel, but the right channel was all distorted (especially noticeable when setting the balance to the R channel).
Long story short, me poking around the inside trying to find the defect, removing components, testing them, RE-testing them, putting back in, etc resulted in this thing biting the dust...a couple of components went up in smoke and I couldn't get it going since, which is why I'm kindly asking for some help, since I read a similar thread for a similar amp (a SE-A70) over here and I was pleasantly surprised not only by the similarities between mine and that one, but also by the similarities of the defects. It was way back in 2010, so I hope it's ok if I link to it here.
The current state of the amp: main relay is not coming on, standby LED flashes normally for around 6 seconds, then begins flashing rapidly indicating a fault (when the relay was supposed to click).
Through my own wits and using the schematic I linked to here for your convenience (PDF is too large), I managed to isolate the problem to the R channel: the center bit of the current sense resistor Z302 read over 2v (measured with - probe of DMM on chassis GND), which according to the manual is interpreted as a fault by the "computer", so I began tracking down to see where it's coming from. By contrast, the L channel read nothing there.
ATM, to prevent further damage, Q309 thru Q316 are removed. During my latest "tests" today, I tried powering it on without D314 in place, since I was at my wits end trying to figure out why I got 4v on the sense resistor and why just about every transistor on that R is going to the full 50v rail. Q306 began smoking without D314 in place. I did the test with a series lightbulb between the amp and the wall socket - I imagine the reaction would've been more violent otherwise. I pulled the plug, removed Q306 and ironically it SEEMS to have survived: B-C and B-E give normal readings and C-E is "open" with DMM in diode mode. I put both D314 and Q306 back in and decided to have another go (YOLO)...this time Q72 started smoking, but same story: removed it, measured it, normal values. I'm worried it may have taken out IC71 as it gets rather warm to the touch. I already replaced it once. To make matters worse, the L channel now died as well - I can tell this because measuring the center bit of Z301 it never leaves -6v (with GND probe of DMM on chassis GND).
Starting to suspect it's not a transistor to blame, but one of those many diodes, since they're kinda "special" and hard to find: MA77W-A and 20A90 (=OA90A-R from what the other thread said).
I think that's enough for now. There's actually more info I could give, but I figure a wall of text will put people off. Please let me know what else you might need and thanks for everything. I'm sure we can get it going again. I DO have decent (if not above-average) know-how in electronics, but transistors have always eluded me
