I did read a few pages on the So You Want To Repair Audio gear but a lot of the links don't work and maybe there is newer affordable gear to look at.
I have a some vintage amps and preamps I would like to go over and repair. I would like to get the tools I will need to test these components for damaged parts, safe slow power up and check factory settings like bias. I have limited electronics experience so I plan to do a lot of reading and watch YouTube videos. I am looking for assistance on what equipment I will need to maintain my gear and to tinker with.
I have hand tools, WES51 solder station, multimeters etc. My amps range from 100 watts per channel into 8Ω to 160 watts per channel into 8Ω.
For an oscilloscope I inherited my fathers vintage Eico 460 oscilloscope. I know it is basic and old and to be honest I am not even sure if it works. Assuming it does can I use it to track problems and check settings? If it does not meet my needs what should I be looking for keeping in mind I just need something that will not be used often. I would rather not use my PC so I would be looking for a stand alone unit.
I will buy a variac for slow power up. Will a 500va unit be enough? Do I still need to build a Dim-Bulb tester if I get a variac?
When I slowly power up an amp to check factory settings do I need a dummy load? If so how many watts do I need? Would it be beneficial to build a dummy load for 2 channels?
I assume I also need audio Signal Generator. Which entry level unit will work?
Is there anything else I need?
