cablephil212
Very Welcome Cleon.
That's why I'm here.
HAHA. Another one bites the dust. They're closing around here too.
If you're going to place an order to PE, go with poly caps. Not that much more.
2 of these: http://www.parts-express.com/pe/showdetl.cfm?partnumber=027-210
4 of these: http://www.parts-express.com/pe/showdetl.cfm?partnumber=027-214
Also, if you can squeeze it into the budget, grab 2 of these:
http://www.parts-express.com/pe/showdetl.cfm?partnumber=090-475
and 4 of these: http://www.parts-express.com/pe/showdetl.cfm?partnumber=260-250
Once you assemble and wire them up, they will become portable units, so any speaker can use them.
If you get the parts, and need help, don't hesitate to PM me.
Have Fun. It's what it's all about.
Phil
OK. Now I understand where you're going. Here's my take on your journey.
When I do an upgrade on a set of speakers, the first thing is to see how they're designed. A simple x-over or a more complex one determines what I'll do to them.
Most of the time, I will just re-cap the x-over, clean the L-pads if the have any, (maybe) change the internal wiring to better wire, and make sure the cabinets are in good shape.
It all depends on what speakers you're working on. If some have a "real x-over", as in a coil and cap for the woofer and tweeter (12db x-over), Then I change just the caps, since the coils rarely go bad (unless over-driven). If the woofer is run "full range", directly off the speaker terminals, then I'll change just the cap for the tweeter.
All of my "upgrades" (unless already there) get new terminals similar to these: http://www.parts-express.com/pe/showdetl.cfm?partnumber=260-309, just not gold plated. When RadioShack was closing their brand out (at about $2 bucks each), I bought all I could from every store local to me. Got about 20 pair. They are very good, quality wise, and accept banana plugs.
So, my final decision is based on how the speaker was built. I have tried adding a real x-over to speakers that only had a cap for the tweeter, and sometimes it worked, sometimes not. It's a crap-shoot, but a fun one. Experimentation is one way to gain knowledge. That's what this hobby is all about. Fun and experience.
I you like the sound of the speakers you have, change out the caps and terminals, then sit back and enjoy. If not, you could try something like this: http://www.parts-express.com/pe/showdetl.cfm?partnumber=260-146, or maybe it's time to pass them on to someone else.
Once you dive into a set, and if you need some help, PM me. Always glad to help a fellow AK'er.
Now, GO HAVE FUN.
