Scottfargo
Hi folks, I have a simple question. I have a pair of old HH Scott two way speakers, in between the speaker terminals there is a plug hole, what is this for. Thanks for any info in advance.
Ahh, that makes sense, thank you sir!Standard rca jack, same as on back of most receivers - but you need a plug with wires on it instead of standard conductor and shield type.
Yes, the grills are very hard to remove, I have not been able to identify the model of these speakers. They look a lot like this, even with the weird metal bar across the tweeter. Mine do not have the cutouts on the wood to fit the woofer. They are all stock and sound great.I do believe that would be for an RCA or a 1/4 inch input ...depending? ......I recently picked up some old Akai Alnico speakers with a single input was a 1/4 inch jack hole. I soldered a couple of speaker wires from the speaker terminals through the hole..these pics don't show me soldering job but the original condition
I had me some Scotts the grill was a a mother to remove, the had a nice midrange to them.Gave 'em to me brother.
View attachment 2304575 View attachment 2304576
Scotts are usually pretty good sounding. They weren't a speaker company, but they had very capable engineers and had good ears, and perhaps because their main line of products were amplifiers, they were aware of how much a speaker can affect an amplifier. So they designed their speakers to be easy loads - most have 'controlled impedance" on the input panel. So even with unprepossessing drivers, they sound fine in almost all systems.
I have found that recapping the crossovers is often very worthwhile - they may sound dim and lethargic, but that is the result of caps going our of spec.
I love the way they sound, if I did anything to them I would just want to rebuild them as close to stock as possible. I don't want a modern sounding speaker, I use them with my Marantz 2220b.The grills generally just pop in, but you have to work them out both at the bottom and the side, which can be difficult.
I'm not sure that increasing the high end extension will actually make the speakers sound better - it will make them sound more like modern speakers with an extended high end, but without an equal extension of the low end, the result will be a less balanced sounding speaker. Tastes differ, and the result may please or dismay. Though if a subwoofer is added to the mix, the result might be very nice.
But I'd check the caps first.
Those are very good full range drivers probably also used in TOTL Akai reel-to-reel tape recorders. Could be made by Sony, Coral or Fostex. If 3.5" to 4.5" they would be excellent candidates for a single driver back loaded horn enclosure like the Frugal Horn Mk3.
