The late 1950s/early 1960s "AM-FM simulcast stereo tuners" had excellent AM sections in terms of audio bandwidth - the good ones also had good front-end performance. These tuners had completely separate AM and FM sections.
This one (attachment) isn't one of those, but it is the direct descendent of one... with built in MPX stereo, in this case...
The McKay-Dymek was one of the best-ever (although I guess if you're really serious, it's hard to beat a Collins R-390!)... try something like a Sherwood S-2000 if you want an inexpensive but excellent AM tuner (with excellent mono FM, to boot).
My Scott 333b has an excellent AM tuner as well, separate dial and all in spite of being FM multiplex natively. I used to listen to CBC Radio One on it and it sounded surprisingly good. Then they decided to move the station over to FM. It sounds even better (if still mono), but the range isn't what it once was.Another alternative is to get a am/fm "simulcast" tuner from the late 1950s or early 1960s, right before FM multiplex was introduced. In that period, some stations broadcast stereo by having one channel on an FM station, and the other on an AM one! For this to sound even halfway decent, the AM tuner had to be very good. In addition, in those days there weren't all that many FM stations, so AM capabilities were a lot more important. You can tell one of these tuners by the ability to completely independently tune for AM and FM.
I have a Scott 330 designed for this system, and its AM section is first rate. But keep in mind that all the tuners made like this are now over 50 year old tube units, so expect to have to have work done on one unless you know it's had a recent refurbishment.
R-390s, while they can pick up INCREDIBLY well, are also noted for SOUNDING like @zz. They were designed basically for receiving either CW or voice transmissions, & EVERYTHING above a rather narrow band is filtered out. There ARE ways around it, but if you're into "Fidelity", a military receiver ain't gonna cut it. But...The R-390's longwave/medium wave brother, the R-389, is capable of some incredible feats. In 1995-96 during the winter, an R-389 in Denver received medium wave signals from France... Now, transatlantic DX is not that unusual, but its generally done in New England or in the maritime provinces....Virtually UNHEARD of 2/3 across the continent..
Actually an R390A can sound pretty darn good if you know how to set it up. On the back to the right of the speaker terminals there is a bridged set called Diode Load. Remove the jumper add a impedance matching transformer to the connection points run this to an audio amplifier. Make sure you have an impedance match!!!!!!!!! You will be surprised as to the sound. The Diode load is tapping into the audio stream before it gets to the final PA section. I do this on my R390A with an ELDICO SBA-1 SSB adapter which uses this signal for it's 14 watt into 4 ohm out there is a big improvement, I once hooked it to a Stereo system and into my Polk M 10B's and I was stunned, it sounded like an old console radio. Totally unusable for utility monitoring and I have other radios that do AM Broadcast, but still.:yes: I believe the R389 has a diode tap as well. As has been pointed out domestic AM broadcasting is a waste (as in feces) land kind of takes away the incentive.
I will say it yet again the very best AM receivers made are the one installed in the high end cars of the 1960's. They are butt ugly out side of a cars dash board but they sound fantastic and can pick up a weak AM Broadcast station better most anything made now. There are incredible numbers of the Delco Wonderbar radios out there. Mine came out of a 1967 Cadillac.Go to a junkyard and ask about car radios tell them you are looking for a Wonderbar radio if the place is like the one in Cheyenne they will have piles of the an shelves. They will be untested but cheap, pick up two or three of them chances are very good they will all work these are some really tough radios
Yep, the "Diode Load" was what I was talking about...Again, however, w/TODAYS broadcasting, you're trying to Polish a Turd..
G'day all, thankfully in this part of Australia we still have AM broadcasting worth listening to. :yes: I listen when I'm in here (Ham Radio shack), with my DIY 'crystal set' double tuned front end feeding my DIY 'tweaked' FET 'infinite impedance' AM detector into my audio system in here, and the audio quality is unbelievably good. :yes: Regards, Felix (vk4fuq) aka catman.
