Hi Q AM
Ya sorry for involving FM in the discussion.
Am stereo? It still exists? I do not know of any stations still adopting this method of transmission. Having AM hi-fidelity is questionable to me at least, due to the nature of the source and the ability of the remove the noise.
If Am stereo is the norm, then the ? remains, why would Silicon Labs, not incorporate this feature into their products? I think I know the answer, AM stereo is dead in the water, has been for some time now.
And I hope that HD FM goes the same way. Just like ATSC?, it sucks or does not exist at fringe signal levels.
I do agree that digital electronics and AM radio frequencies are an issue, but that is the way it is these days with electronic noise saources, i.e. fluorescent ballasts/fixtures/lamps spraying RF. You need an external antenna and mount it far away from the noise sources, if you can. Ain't so easy, in a metropolitan area.
My NRD-545, while being a Top-Notch receiver otherwise, has a HIGH noise floor because of CPU & fluorescent display issues.
Well maybe they did not do such a good job at shielding,filtering these noise sources? Like most are saying, AM is a second thought with most tuners.
To think that a DSP is of no use in a AM receiver, is what I'd call short sighted. Maybe you are correct, Silicon Lab's do not know what they are doing, NOT.
If $ permits, like on a Carvier budget, you can design very low phase noise VCO's, PLL's etc as it is done with hi-end Signal generators.
Before people shoot down a DSP radio for AM, have any of you actually designed, listened to a Si4770 part that has been implemented correctly?
