High End Setup?
You don't want an integrated unit either. You definitely want a separate pre-amp and amp or amps! If you are on the West Coast go to Scott Walker Sound. The east coast Audio Classics. Central US, I like Bjorns in Texas, and I guess Listen Up in the Rockies. Don't know about the mid West and Great Lakes region or Georgia Florida.
There are some very nice integrateds so I don't think it's an either/or situation. I would love to have me an Accuphase integrated amplifier any day...
If wanting to start out slow an integrated like the Kenwood KA-7300 can grow with him allowing a power amp/amps to be added later. The Kenny makes a superb preamp, I have one connected to one of my Belles 1 amps driving my AR's quite nicely.
It's phono stage is pretty schveet also as long as MM, MI, or HOMC are used. Of course an outboard phono stage could be added for LOMC if desired, the options are many.
The problem with Accuphase integrated units is the power available fairly low, but if you have efficient Tannoys or Klipsch that really isn't a problem. Just stay away from Martin Logan or Magnepan .
i would be more interested in "bang for buck"
my very modest current system cost me about €250 and I love the sound. I have nothing that is exotic but for my application its perfect for my 5metre x 5metre room at low to mid volume playing
I guess spending $2k on a vinyl playing setup will result in some very fine sounding gear, providing you dont want to fill a gymnasium with sound.
For me buying a top of the line Mcintosh for example for my small room is ridiculous
You don't need to jump in all at once start out slowly and build your system piece by piece.You may get to a point where your happy with your system and won't need to go into the high end.Spending more money doesn't guarantee better sound. Just remember speakers and cartridges make the biggest difference when it comes to improving sound quality.
Did someone suggest he do so?
Given his budget, and assuming new, I suggested a Yamaha integrated.
. . . I was talking with my local record shop owner and he said a good high-end set up would cost a total somewhere between the $1200 to $1500 budget range so that was where my mind was budgeting for. . .
from my understanding I would need the following:
An Upgraded Turntable
A Receiver
Speakers
Shelfing
Any suggestions on what to get?
There are lots of different ways to go at your stated budget. If it were me, I think I'd start with a Marantz PM6007 integrated amplifier. It's not a receiver (it does not include a radio tuner), but it's the lowest cost, most highly acclaimed amplifier that I know of. What HiFi, comparing the Yamaha A-S501 to the then-current PM6005 said:
"However, the A-S501’s composure falters a little when things get complicated. It starts to sound just a touch confused, losing track of subtle instrumental strands as the piece really gets going. Let’s make this clear; it doesn’t fall apart, more that the sense of control and stability is diminished as if the amplifier just can’t quite keep up. In direct comparison something like Marantz’s PM6005 sounds much more settled and confidant. Dynamically it’s a more exciting listen too."
That was a couple generations ago for the Marantz, and their reviews of the PM6006 and PM6007 show improvements for each new model. A friend of mine has, I believe, the PM6005 (though it might be the PM6004), and it sounds great driving his B&W CM5 speakers. At $699, that eats up about half the budget, but I think it's money well spent. A separate radio tuner could be added, though for many years now I have gotten my radio entertainment (talk shows, ball games) from a C. Crane CCRadio 2.
For a turntable, my feeling is that truly superior sound can be had in the Rega Planar 3, but that's not going to fit the budget. The $475 Planar 1 is probably the best-sounding unit in your price range, but if you have a desire to play around with different cartridges, its non-removable headshell makes that difficult, and when those flying leads break, it's a fiddly or expensive thing to fix. Not that you couldn't do it yourself if there's no dealer you're working with to do it for you, but cartridge swapping has higher risks than on something with a removable headshell.
Another option could be the $399 Music Hall mmf 1.5, about which Steve Guttenberg wrote, "The mmf-1.5 may not have the gutsy bass brawn of a big direct drive turntable like a Pioneer PLX 1000 ($699), but the mmf-1.5 wins on finesse and regularly occurring musical epiphanies that make it hard to stop playing one LP after another." One reviewer said of cartridge upgrades for this model that a $329 AT-VM740ML didn't sound as good as the stock Music Hall Melody cartridge, but the $99 LP Gear The Vessel A3SE "proved to be a better match and took the performance into a different league, knocking on the door of some more expensive turntable/cartridge combos." https://www.post-gazette.com/busine...table-worth-every-nickel/stories/201802040045
Another well-regarded model is the $249 AT-LP120XUSB. I bought one last year for 78's, but I've been surprised at how involving a listen it provides for LP's, too, particularly after I relegated the stock cartridge to 78 rpm duty and mounted a $79 Sumiko Oyster on another headshell for LP's and 45's.
Speaker choice depends so much on your room size and configuration, as well as your own ears and tastes, that it's hard to give a firm recommendation. For a budget speaker, I really like the Bose 301 series v ($328 per pair, plus another $90 for the stands). In my previous apartment, I could set them up properly to take advantage of their rather unique design with the extra rear-mounted tweeter. They were a better match for that room than my much more expensive Vandersteen 1C's were. In my current listening room, I can't place the 301's properly, and the smaller Bose 201's actually work the room better than their bigger brother.
For shelving, there's nothing wrong with the tried and true dorm room staple of bricks and boards from the hardware store. I've used that kind of shelving for over 40 years, though I did find improvement with an isolation platform to put under my turntable and have also used a dedicated turntable stand. The isolation platform I bought is no longer being made; it was something a previous Linn importer arranged to have made specifically for the LP12, though I have found it to give improvements to a Well Tempered as well as my current Rega RP3. One of the things that platform helped with was having adjustable feet to get the turntable perfectly level; the LP120XUSB has height adjustable feet to take care of that particular issue. I don't know about the feet on the mmf 1.5, though the manual states, "The rubber feet have been specially designed to isolate the unit from excess vibration. The feet may also be used to stabilize the main body horizontally." It might take a call to a dealer or the importer to see if the word "stabilize" includes the ability to use the feet to level the turntable.
OP, how important is vinyl as a medium vs getting the best sound quality you can afford? I know you mentioned records but do you have many of them? If not you might want to forget about chasing a high quality TT setup within your budget and go digital.
Kef just released new versions of its LS50 line. I’d be willing to bet you could grab a pair of original LS50Ws for your budget. This would give you awesome sound in an all in one solution.
Getting top tier sound out of vinyl is much more costly than doing the same with digital as the source. Analogue vs digital debate aside. Just a thought.
I certainly don't pay attention to What HiFi's reviews. Surprised that anyone does.
I pay attention to review sources whose information turns out to match my own experience when I've had a chance to listen for myself. What HiFi's conclusions have matched my own on a fairly regular basis.
