Thank you. Well, I know for sure that the Quad used 301s, and I opened up my AHB2 and I thought that there were a pair of TI opamps on the main board- which is very complex I might add.I will want two boards for sure. Do you have dimensions for the pre pcb yet Wyn? Just looking at existing cases I have . Also do you know the max current consumption of the pre? Off topic but I watched an interview with John Siau and Laurie Fincham where they stated the AHB2 was all discrete . I know the DAC3/ LA4 use op amps .
I will want two boards for sure. Do you have dimensions for the pre pcb yet Wyn? Just looking at existing cases I have . .
Dimensions not quite fixed as some jumpers are still to be placed, but the upper lower/upper bound is 145mmx100mm/ 150mmx100mm.I will want two boards for sure. Do you have dimensions for the pre pcb yet Wyn? Just looking at existing cases I have . Also do you know the max current consumption of the pre? Off topic but I watched an interview with John Siau and Laurie Fincham where they stated the AHB2 was all discrete . I know the DAC3/ LA4 use op amps .
It looks like a preamp board will likely be $11 each plus shipping. The cost for me to purchase a minimum order of 5 boards of the maximum dimension is $55.Dimensions not quite fixed as some jumpers are still to be placed, but the upper lower/upper bound is 145mmx100mm/ 150mmx100mm.
The latest 3D image, including the input load components and jumpers.
I've started investigating PC board fab houses...
Wyn, please, count me in for 2. I will paypal the amount as soon as I get a firm quote on boards plus shipping.It looks like a preamp board will likely be $11 each plus shipping. The cost for me to purchase a minimum order of 5 boards of the maximum dimension is $55.
Without @HalfApt this would not have been possible.I would like two of each Wyn. Great job!
10-4. Thanks.You have to remove the .txt extension and leave the .asc.
You need to add the .txt extension to allow the file to be uploaded to AK.
The latest schematics are a little bit different, and they will be posted once the board is complete.
