Hi guys! I need some help/guidance with this amplifier. I got it cheap together with it's premp HCA-7500, which is working fine. But the power amp has weird distortion when i turn the volume above the certain level, sometimes it's so violent, that even the protection is kicking in and the relays disengaging. I made a video about it, you can check it out.
The previous owner already did a full recap on it, basically every capacitor has been replaced, including the main filter caps. He replaced the bias pots. The driver transistors Q757 and Q758 are also new. What i managed to discover yet:
The distortion appears on both channels. That is weird since the amp is a dual mono construction, basically everything is doubled, transformers, rectifiers, protection circuits, ect.
It's definitely coming from the HMA-7500, i have already tried another source, so the HCA-7500 preamp can be ruled out.
No matter if i use direct coupled or cap coupled input.
No matter if the switch is set to 4 Ohm or 8 Ohm.
If i push BTL button, the LED lights up, i hear relay click and i get no sound. I'm not sure how this BTL (which i believe is a bridged mode) supposed to work...
The main voltages are rock stable, i do have +56 and -56 volts, even when the distortion happens, the voltages are steady.
Voltages on the IC711 (which is some kind of preamp i guess) are there and stable.
I checked every solder joint for cracked solders, the suspicious joints were reflowed.
No loose cable connections.
I did visually check every component, every resistor for cracks or burn signs, i could find nothing.
I will attach some photos and the schematic here, unfortunately it is way too complex to me, i don't really understand how it works, and what are LN, LNF, LP, LD for instance. I did measure the signal on these points and the distortion is there which tells me that the problem might be somewhere before the power stage section.
It's still not clear to me why do i have it on both channels. What is common in this amp that could effect both channels??
Any help would be nice!
