Maybe my description "distortion" wasn't accurate for this issue, sorry i didn't know how to describe it better. I will check every connection one more time, maybe i will find something. The amp definitely had an accident before, probably it was dropped because the big board was broken around the relays, and someone has repaired the broken traces. But that section was the first what i checked with multimeter and i couldn't find any broken path, everything seems all right there...Wow. To say the least, that is not the sort of distortion I had imagined. I had assumed that there was just a non-linearity in the amp's response, but this seems more like the amp is breaking into oscillation at points that are at least loosely correlated with the phase of the input signal.
Truthfully, I have no solid ideas. You should double-check that all connections, especially ground connections, are good - but I gather that you've already checked that. You might also try tapping the relays at the onset of symptoms, to see if the symptoms change.
I think one thing I would try is to disconnect the collectors of Q759 and 762, which are meant to detect excessive current in the output stage and, if detected, disable the signal drive to the output stages. It would make sense to first check the output MOSFETs' source resistors, the 0.22 ohm parts. (You won't be able to accurately measure such low resistance values, but they should measure as less than 1 ohm.) The big flaw with this line of thinking is that it seems unlikely for an over-current detection problem to affect both channels.
The amp is acting really wild, i haven't seen such thing before, probably that's why i could not describe it better than "distortion"...
Yes the driver transistors were replaced by me. On right channel it had the original ones, Q757 and Q759, 2SD669 and 2SB649. But on the left side were different transistors (i can't remember their type but i know they weren't proper complementary pair. So i decided to replace all four, i used 2SC2690 and 2SA1220. I thought they will be good replacements. Your thoughts on that? By the way the amp had this issue before i did replace those transistors.
