HK 330b chassis measuring 120 volts
Thank you all for the replies. The shock (tingle?) I get from touching the chassis is roughly the same as the feeling you get from licking a 9V battery.
I took a look at where the AC lines are and everything looked ok as far as I could tell. Does someone with more of an EE understanding/background have any thoughts as to why the AC section of the MV vs the RV variants looks different (no cap on the RV, resistor on the switched vs non-switched side, etc)? Just for fun, I may try replacing the capacitor to see if things behave any differently.
RV:
MV:
Yes, that's annoying as hell..:yikes: even though it is just a "tingle".. Look closely at your power cord and you will notice a stripe or two embossed the full length of one conductor only. That conductor is supposed to be the Neutral conductor. The non-embossed conductor (HOT) should be going through the power switch. If it was wired correctly by the assembly worker that is. Anyways, plug it in with the Neutral conductor to the neutral in the receptacle. In modern 120v outlets that are polarized, it is the wide slot. That is also assuming the electrician wired the receptacle correctly. In units with non-polarized plugs, there could be full AC on the chassis if plugged in reverse.. That is why the "death caps" were used to bleed off the stray voltage. They were referred to as a "hot" chassis. So check your power cord to be sure if the non-embossed conductor is indeed going through the power switch. If so, put a white mark (I use paint) on the side of the plug where the embossed conductor is to eliminate that "factor". That can also eliminate strange "hum" issues in some units.
I agree... stupid design.
Just noting plug polarity.. OP can cut that cord on the inside leave a 1/2 inch and using a lighter heat the insulation up and curl up and pull the outer cord with a pair of needle nose.. that'll save the cord restrainer nugget for reuse.
Thanks, all for the input.
Update for anyone interested: I replaced the capacitor with a safety rated one and got the same results as I did with the original one in there. I am very tempted to leave the capacitor out and make the AC section of the circuit look like the US only version does (only a resistor without the cap).
I really find this confusing, hope I'm not alone. It sounds like there's a piece of this puzzle missing.
People are different in many aspects. I think bubbletrou is just more sensitive than most to small electrical currents. I had a chemistry teacher in High School that could put his thumb and finger directly across the 120 VAC line and feel nothing more than a slight tingle.
Haha I feel the same way...does anyone else have this variant? It would be nice to see if this is just the normal behavior of the receiver.
I do have a US-only variant as well that I was planning to pull out tonight and do some testing on.
Would be interesting if you would actually measure the leakage current. Preferably with the standard circuit I posted earlier (the resistor would not need to be 10W, with your currents 1/4 W would be fine) or just with the DMM set to AC current and connected between the receiver chassis and the ground pin of a three pin power socket.
I haven't seen anything like that ac configuration in many sm's read. Often we see grounds off misc pcb's from the low v end of pcb circuits, i.e.a central centered pcb main board like a star.. sony uses a chassis ground off their main boards.. sansui uses a lug type of mount. Never could figure out Onkyo touch knob tuning deal.. certainly a new cord would assure that the plug is plugged in the proper orientation. I just don't like it. :D
If I'm restoring vintage gear with a 2 prong cord I always replace it with something keyed. I also check the condition of all receptacles with a plug in tester. Simple, cheap personal protection.
If the line cord is OK but the plug is unpolarized I just trace the neutral and use wire cutters to center split the plug blade. Then pry the cut wider to only fit polarized outlets. (NOTE: I came upon this idea on another forum [don't remember where] and it works swell.)
