HK 730 Twin
Joe-nobody
Can a HK 730 twin safely handle double stacking large advents? From the little I've read I'm lead to believe that it can, but I've been wrong before.... thanks for any insight.
Depends on how you wire them up.
You could wire them in series and connect them to Speaker A and be safe.
You could wire them individually to speaker A and speaker B. Be careful with the volume knob and watch for increased heat from the unit.
I would say give it a try and check for any excessive heat being generated. If it stays cool and you don't crank the piss out of it, you should be fine.
Is that particular unit actually designed to run speakers in parallel or series? All it seems to say on the back is that connected speakers should be between 8 and 16 Ohms and that is sometimes and indication of a series setup in wiring. One way to tell is by hooking up only one pair of speakers and then selecting both A and B at the same time on the front. If no sound comes out then it is wired in series. If it plays sound then they are wired in parallel.
According to the manual, if all speakers are 8ohms or above, you can use both A and B (which is the same as wiring in parallel) at the same time. Only one pair of 4ohm speakers can be used at a time.
