Thank you for the response. I want to ensure the receiver is in working condition and then replace all electrolytics and all other compoonents that are known to be problematic like the 2SC1400's. If anyone has a more recent Mouser BOM that I could start with I'd would appreciate it since the one posted is pretty old.
You'll want to likely order the small signal transistors if you don't have them (KSA992, KSC1845 do the bulk of the subs there; and whatever you go with for the heat sink and other main amp board subs).
I am nearing a Mouser order for the main amp boards, tone and PS area and have sourced the best (to me, far from an expert) in stock there for these three areas (if you remove the parenthesis you can just plug this into the BOM builder; the quantity follows the part number and the BOM builder will note that.) :
Power supply
647-LLS1H682MELZ 4 (main caps) or 232-50PK4700MEFC18X4 4 (direct fit)
647-UPW1C222MHD1TO 4 (rectifiers)
647-UPW1E471MPD6 2 (rectifier)
Power amp boards
652-3362W-1-102LF 2 (1K pots)
647-UKL1C101MPDANA 4 (100uf 16v, sub for 10)
647-UKA1A102MPD 4 (1000 uf, 10v)
647-UKL1A221MPDANA 2 (220, 6.3 general purpose)
Tone and local rectifier boards
647-UKL1C101MPDANA 2 (Selector top board 2 Capacitor Electrolytic 100 uF 10 V signal)
505-MKS2C041501H00KI 2 (Tone control and local rectifier 2 Capacitor Electrolytic 1.5 uF 35 V signal)
647-UKL1C101MPDANA 2 (Tone control and local rectifier 2 Capacitor Electrolytic 100 uF 10 V signal)
647-UPW1E102MHD1TO 4 (Tone control and local rectifier 4 Capacitor Electrolytic 1000 uF 25 V power)
667-EEA-FC1E220B 4 (Tone control and local rectifier 4 Capacitor Electrolytic 22 uF 16 V signal; NOT MANY OPTIONS EXIST FOR SIGNAL PATH)
647-UPW1E221MPD1TD 2 (Tone control and local rectifier 2 Capacitor Electrolytic 220 uF 6.3 V power)
