I pulled my A500 out of storage today in anticipation of it being the next project. I'll be stripping off the iron for a new build, and the various options for output tubes are my primary consideration. I do have a NOS quad of the original tube type (7355), as well as several quads of used tubes. However, I'd like to eventually sell those and use the proceeds to fund other projects. 6L6 variants like the 6L6GB or 6P3S-E are another option, but previous experiments in the circuit have indicated that they don't perform quite as well as the original type, probably due to the low-ish primary impedance of the output transformers. Another member here recently built an amp from the A500 output transformers using PPP 6V6s. That's a better match for the transformers, and it appears to have worked out well. However, I'm not overly excited by the prospect of needing eight reasonably well-matched output tubes for one stereo amplifier.
At this point, I'm also still considering the EL34 for this build, something that's been discussed here before. I've always considered this tube to be the most similar analog to the 7355 in terms of operating conditions and optimum plate load. The 1.5A heaters are a significant problem of course, but I have two A500 power transformers now and am strongly considering building monoblocks. That resolves all the issues regarding heater current, because each transformer would see slightly less heater draw with two EL34 in mono than a single transformer does with four 7355 for stereo.
To gather more data, I rewired one channel of the A500 to receive a pair of EL34. No output tubes are installed in the other channel, and the grid circuit has been modified so fixed bias can be applied from my bench supply. Each cathode is grounded through a 10Ω resistor for monitoring. The driver tube filaments that were previously powered by output cathode current are now connected to the main 6.3V heater wiring. So far, the results look pretty good.
EDIT: Data previously posted here has been deleted due to an issue discovered in the amplifier that was affecting results. Revised data has been posted further down the thread.
Jack
Jack
