FlaCharlie
I would think that the chances of finding someone who is parting one out is pretty slim.Though not useful, I would like to keep the unit as original as possible. Chances of someone parting out a unit where I could get a working PEC should that be the case?
No problem, though. Just build the PEC circuit on a small piece of perf board. The High Cut consists of 2 resistors and 2 caps. It won't look original - although you could leave the disconnected PEC in place for looks and mount the perf board below deck - but it will function as intended. I'd suggest replacing the High Cut on both channels with new parts.
For now, just wire around it to confirm that it's the problem.
Just disconnect (again, don't just add a jumper but totally disconnect) the wire that goes from the .2 coupling cap to the High Cut switch and pin 1 of the High Cut PEC. Then disconnect the existing wires that go from pin 2 of the High Cut PEC to pin 2 of the Treble PECs. Then run the wires (one from each coupling cap) directly to pin 2 of the Treble PEC for each channel.
This leaves the Low Cut and Blend controls in place and only eliminates the High Cut.
