HK cit II bias adjust??
There are instructions on Jim McShanes tube site. Anyway you don't want to go 100% like the original instructions. He sells resistors to make the meter still read correctly if you want to use it. It should pay to also try to go as low as you can go where it still sounds good, that way you will gain the best tube life. I think the schem. manual is in the AK database.
