Hooking up Electro Voice LR4SAT speakers
RSMRecording
I have 4 vintage Electro Voice LR4SAT column speakers (line array type) and need help to hook these up correctly.
These speakers have a voltage selector for 25, 70.7 and 100 volts line. I have a crown D-75 power amplifier that I planned to use with these speakers.
Hope someone can tell me what voltage line I should use.
Thanks,
Robert
Ideally, you'd open up the speaker (or whatever necessary) to bypass the constant voltage transformer. By doing so you'd run the speaker at a more conventional 6-8 ohms.
