Dual1215S
The Denon has the usual Tape Monitor plugs, but also contains a Pre and Main outputs as well.
Followed the Optimus operator's manual to hook up to the receiver via tape monitor and while the LCD indicator works, the EQ itself isn't linked in to the sound itself. Tried all the Tape Monitor options on the EQ and receiver - still no luck.
Changed it to the receiver's Pre and Main outputs to the main in and out on the EQ. Works fine, but the LCD indicator sits idle.
I just don't get it. I want both LCD and EQ to work. Any suggestions?
The Denon is a DRA 1025-RA and the EQ is an Optimus 31-2030.
Denon Pic: http://www.audiokarma.org/forums/showthread.php?t=187322
Optimus EQ Pic: http://www.canuckaudiomart.com/image.php?image=2128439&is_user=0
