Ghoulardi
Well-Known Member
I will try a couple of things based on what I have read here, but that won't be until sometime tomorrow as work comes first. I will post pictures of the unit if I still have no luck. The unit may be "white van-ish" as I don't know a lot about it. I can see where the brand "Audiofile" would bring this to mind. The unit is very heavy, solidly built, and does not seem BPC or cheaply built.I bought it from a seemingly reputable seller who used it in his own system for a time. I have sent him a question or two, but have not heard back yet. There is certainly a chance that the unit just doesn't work properly, but I don't expect this to be the case. I doubt that the unit was damaged in shipping. The way it was packed for shipping was excellent and the package could have withstood a pretty major pounding without incident.
I have a line in to the surround unit (line in jacks) from a tape out of the main unit with no return line to tape in. I have also tried this with a line back to tape in. The speakers are connected to the surround unit via spring clip speaker terminals on the rear of the unit. The front has four different LED type readouts (min/max) for each of the different outputs. I can see these lighting and changing in unison with the music/signal. The buttons on the front are monitor( I assume tape monitor ), matrix, surround, hall, test, and phantom. There are two adjustable knobs on the front, sub output and line in level control. The front also has three volume control +/- buttons ( rear, front, master ). This seems like it should be easy. I must be missing something basic. Thanks.
we have sound. Thanks very much to all who replied and sent their help.
