saggy
These go to 11
so i just got my first tube amp and I’m already curious about how to change tubes. I bought it used, and while the tubes still have life they’re about 2-3 years old. I have been playing it non-stop for a week and notice the bias drifting a touch. I don’t have a tube-tester but the unit has the bias switch which I’ve had to reset once. (Is that normal or should the tubes stay “biased” longer?)
I’m curious about how and when it’s necessary to change the tubes out and if you change just a few at a time or do them all at once. And to be clear, I’m the same form of idiot as the rest of you when it comes to sitting still with gear!!
Just for reference it uses the following tubes:
EL34 (6CA7) x 4
ECC83 (12AX7) x 2
ECC82 (12AU7) x 1
I have a feeling this is going to get expensive pretty quickly...
EL34 (6CA7) x 4
ECC83 (12AX7) x 2
ECC82 (12AU7) x 1
