primosounds
Powered with pure tube sounds.
Like i said you need to follow the owner's manual. What the fixed bias setting for a power tube is not the same for every amp. It is a determination based on the circuit.
And yet, the designated setting for my VTL MB-450s is 270-300 mV using 6550Cs - which also use KT-88s as well.
Go figure.[/QI
Go figure.![]()
In that case the resistor is larger than 1 ohm or for multiple tubes. It is likely 10 ohms then running at 27-30 Ma. Call Luke and find out.
That is the voltage reading not the current reading. Not all amp makers use a 10 ohm voltage sensing resistor on the cathode. Dynaco uses 15.6 ohm resistors, and i have no idea what it is in your amp. So, best to follow the instruction manual. Also the VTL is PPP, parallel push pull, what is it 8 or 12 tubes per channel? So, the per tube setting of the cathode current maybe different from a simpler 2 tube per channel amp. Anyway, being an owner of that vtl 450, must bring a smile to the face of your tube dealer when you walk in the door.
Certainly doesn't have to. New production, while often looked down upon by purists, can get you as close as you want to the sound you are looking for. Unless you go Genalex KT77's for the EL34's, you are looking at under $100 for your preamp/front end tubes. I like the Genalex Gold Lions for both AU and AX. There seem to be lots of people who agree, and they are only about $30 on eBay and $40 on Amazon. You should change all 4 power tubes at the same time, if they are roughly the same age. While I didn't care for them, I just got a quad of Electro Harmonix EL34s (new production) for like $65. Unless you get a great deal, or have an amp that warrants the price, not much need to get into the expensive end of NOS, although there are cheap NOS tubes out there too.so i just got my first tube amp and I’m already curious about how to change tubes. I bought it used, and while the tubes still have life they’re about 2-3 years old. I have been playing it non-stop for a week and notice the bias drifting a touch. I don’t have a tube-tester but the unit has the bias switch which I’ve had to reset once. (Is that normal or should the tubes stay “biased” longer?)
I’m curious about how and when it’s necessary to change the tubes out and if you change just a few at a time or do them all at once. And to be clear, I’m the same form of idiot as the rest of you when it comes to sitting still with gear!!
Just for reference it uses the following tubes:
EL34 (6CA7) x 4
ECC83 (12AX7) x 2
ECC82 (12AU7) x 1
I have a feeling this is going to get expensive pretty quickly...
No need to as the bias procedure and recommended values are covered in depth in the manual. I'm one of those folks who actually does read the instructions.It is likely 10 ohms then running at 27-30 Ma. Call Luke and find out.
No, sorry, that's overbiased in voltage, I am referring to current. If the current is too high, the tube is over biased.You are correct, overbiased means the tube is running cold or turned off. Unfortunately 99% of the tube owners have been misinformed. What's worse it that they don't seem to care to get it right.
Have you tried different 5687 types? I used to run MFA M75 into Magnepans and that was a good combo. The amp used the 5687 as driver/splitter tube. After rolling 7044, 6900, and 7119 i settled on the Amperex Holland 7119 as the best tube in that amp.I roll e'm until I find something I like and then stick with it. This process took about 5 years. Then I purchase backups. My rectifier tube is NOS Mullard, so that gets expensive. All I need for my 5687 tubes is quiet, so inexpensive (relatively) NOS RCAs are the way to go.
My impression of the 7119 vs 5687 was that the Amperex was more "airy" or bloomy. While the 5687 had a darker sound . The difference was quite striking. But since the application is different it is hard to say without trying.My RCAs are 60s black plates. Tung-Sols were quite forward. Sylvania GBs were goopy and too "tubey." Have not tried the Amperex Holland 7119, but it is on my short list. I guess I'm not done rolling. FYI - I'm loading up a ModWright tube linestage.
I used to own a RM9, if that is the one with 4 x el34 per channel. One of my buddies lusted after it so i sold it to him, for really cheap considering what they sell for nowadays.Glad you mentioned the ST 70. Voltmeters were not very accurate at the time (no digitals) so David Hafler used that value to produce 1.56 volts across that resistor for 100 mA of cathode current for the pair. He then told you to calibrate your meter with a fresh flashlight cell which is also 1.56 volts and thus match whetever your meter read. Those were the days.. It also turned out that value actually reducted the distortion. I used 15 ohms in the RM-9 to light a LED
Sag-Please help settle an argument, when you said this, did you mean bias voltage or bias current?I have been playing it non-stop for a week and notice the bias drifting a touch.
BIAS CURRENT.Sag-Please help settle an argument, when you said this, did you mean bias voltage or bias current?
BIAS CURRENT.
sorry for being AWOL on this thread...
https://hifipig.com/unison-research-triode-25-amplifier/
"For those that don’t own or know how to operate a multimeter, or have the confidence to go poking around within the internals of a valve amplifier to adjust the valve bias settings, Unison Research have thoughtfully provided a simple yet effective way of adjusting the bias current settings. "
The Amperex Holland ECC83 I bought was "boomy" to the degree I feel like I may have gotten a microphonic tube.My impression of the 7119 vs 5687 was that the Amperex was more "airy" or bloomy. While the 5687 had a darker sound . The difference was quite striking. But since the application is different it is hard to say without trying.
It's been a real education, getting this thing. I'm so happy to have the resources of AK at my disposal.If that is your amplifier then most likely that is a current meter. I presume you set it to the center between green and red. If so you are adjust bias voltage and measuring cathode current. We only have to change one word in your last sentence from "bias current" to "idle current" and then all is well. Of course you might want to know how many mA that meter is reading.
Yet your quote said, "Unfortunately the loose language of current audio..."That's all I am trying to do here, not argue with you
