cpt_paranoia
Addicted Member
In the real world of audio performance, they can have a profound effect on transparency and dynamics.
You clearly haven't heard a corrupted data stream if you think power supply noise is profound...
Ah, redundant marketing speak.No, it explains the terminology.
The difference between you and I is that of experience. It is truly difficult to imagine what you’ve never been exposed to.What effect do you think the power supply has on the digital output of a purely digital device?
May well be. I just observe the considerable audible differences I hear across multiple systems.You clearly haven't heard a corrupted data stream if you think power supply noise is profound...
You really should drop the textbooks and experience reality. Only then will you understand.
I work in a department full of EEs, computer scientists and mathematicians -- after a prior career as a software developer -- so I'm quite used to taking a theoretically-sound design into the field only to watch it fall over spectacularly. Of course, there's always a good reason -- usually some missed-but-obvious-in-retrospect factor somewhere -- but it always turns out to fit within the theory because the laws of physics (and thus electronics, acoustics, etc.) cannot be broken.My everyday with the EE’s I work with. I am going to steal it, “it worked durning modeling”. They design something, ask us to work and/or install the prototype or proof of concept and get bent when we tell them it probably will not work right in the environment it is being installed.
I'll take your word about experience with the spectacularly poor ("corrupted data streams"). Must be quite storied indeed. Sorry to hear that.The difference between you and I is that of experience. It is truly difficult to imagine what you’ve never been exposed to...
Good engineering always begins with proven concepts and conservative design. It should not, however, end there. Then you go to alpha and beta testing to independently validate the results!My everyday with the EE’s I work with. I am going to steal it, “it worked durning modeling”. They design something, ask us to work and/or install the prototype or proof of concept and get bent when we tell them it probably will not work right in the environment it is being installed.
Which kind do you prefer?
Can we please get back to the original query with the specific devices
Use an Allo DigiOne digital board instead feeding a Music Hall DAC 25.3 with its own linear supply.I'd look to concentrate any power supply improvements to any DAC 'hat' being used...
It isn't clear whether Apple TV is receiving the audio data stream from the controlling MacBook/Mac/iPhone -- and if it is, whether the source file is the same on all the devices -- or is being instructed to obtain the audio data stream from iCloud/iTunes directly, or -- perhaps depending on which device is the controller -- both.Can there be that much degradation over WiFi? What if the OP's router isn't 802.11ac dual band? Could the iPhone degrade the output when backing down to an older WiFi standard? Some here say no, but then what could be causing this very perplexing result?
In any case, the audio quality may be affected by network degradation (which could be due to both environmental issues and device differences) and/or source file/stream differences.
More information about the OP's system -- per @cpt_paranoia's questions -- and/or experimentation is needed.
With the latter in mind, today I wasn't able to find out if an Apple TV was still knocking around at work. I'll try again tomorrow.
Yes, but the OP hasn't identified what he was using to play the content from his MacBook/Mac/iPhone through the Apple TV, has he?It is clear because he is using AirPlay to push the iTunes playback content to the ApplyTV. If AppleTV was pulling the content and processing it then he'd have to be using the Apple Remote app. AirPlay doesn't control or play anything, it's just the interface to the the WiFi pipe.
2017 MacBook Pro (2.9 ghz i7, macOS 10.14); mid-2012 Mac Pro (2 x 2.66 ghz 6-core Xeon, macOS 10.13.6); iPad 2 (iOS 9, as I recall, or whatever was the last update available for the iPad 2).Hopefully you can find the AppleTV to play with. What devices do you have on hand to use as potential players?
While it might not be clear... That is not how AirPlay works. Airplay has Senders and Recievers. The content is push to and played out from the Apple TV. MACS and phone are senders.I.e., it's not clear whether the content is being "cast" and retrieved by the Apple TV, or streamed from the controlling device's local storage to the Apple TV.
The terms that Apple uses are certainly sender and receiver, but depending on the content being played, typical "casting" systems don't necessarily send audio (or video) data from the sender to the receiver.While it might not be clear... That is not how AirPlay works. Airplay has Senders and Recievers. The content is push to and played out from the Apple TV. MACS and phone are senders.
