To whatever extent it might be argued or imagined to do so, a conventional vent does the same....EDIT: either i missed the increasing the effective area of the bass driver, or it was added later. This would be a poor analogy for what a PR does.
To whatever extent it might be argued or imagined to do so, a conventional vent does the same....![]()
Two typical 12" woofers would have a similar amount of cone area to a single 18" driver.
Gave away a pair of the Cannons some years ago -- I believe they were made by ESS, like tarior said. My buddy still has them, and is still happy with them.
Yes, it is another active driver, but the upper extension is completely limited by the big mass of MDF in the centre of the cone (which ultimately causes spider sag, but it can be corrected). I would presume that this not only greatly increases control of the frequencies the driver is producing, but also would speed up the timing a great deal. Certainly works for me with my 2Cs!Thanks for the info:thmbsp: I think I more or less understand the principles behind the passive radiators. However, this raises another question for me with regard to my Vandersteen 2C's. They use an 8" woofer combined with a 10" Acoustic Coupler (10" critically damped long-cone; 1 1/2" four layer voice coil with ventilated aluminum former). "The 10" rear-mounted acoustic coupler, together with the 8" forward-firing woofer helps to correct for "real world" conditions such as box loss, thermodynamic loss, and active/passive transfer non-linearities." 2C manual As I got lost after the forward-firing woofer part of the statement, could someone help me to understand how this works compared to a passive radiator? It appears to be another active driver, but is it?:scratch2:
I have a set of "Targa by ESS" that look prety similar to the pictured Canons except they have dual cone mids and a panasonic dome tweeter. Refoamed the woofs and PR's and so far to lazy to put em together and see how they sound.
sorry for the derail, btwWe need to find a pacifist to answer that one.how passive are effective radiators?
dnewma04;1898042...they also have less port noise...[/QUOTE said:Well no ****! There's no port!
Heh, heh...
Back around 1980 Speakerlab used what they called an "Active Hybrid Radiator" in several designs, the Delta 1 Hybrid Type Five, and Delta 1 Hybrid Type Four. It was not quite a PR, it was actually a woofer.
The Type Five consisted of a leaf tweeter, 2" Dome upper mid, 6.5" poly cone mid, 10" woofer, and 12" active radiator. The Type Four consisted of a leaf tweeter, 4" mid (a Polydax unit), 8" poly cone woofer, and 10" active radiator. Both were in tower type cabinets.
They also had their Speakerlab 15, which had a leaf tweeter, 8" poly cone woofer, and 10" PR on front of a tower type cabinet. The Speakerlab 17 consisted of the same leaf tweeter, a 6" poly cone mid, 8" poly cone woofer, and 10" PR on the back of a tower type cab.
This "AHR" worked in conjunction with the woofer down where the woofer would have begun to roll off. The AHR itself was rolled off higher up where the woofer was more effective.
