If the parts are functioning correctly leave them alone, no need to change them. I am not familiar with the diagram of your unit, so I can not tell their function by the designators Q401, Q421 etc. It will help if you post the designators together with the part and rank of the parts. For example, Q401=2SC1345F , especially for the differential pair. Some of the parts that you measured have gains quite large. I can not tell if they are well matched because with the designatror I do not know which ones form part of a differential pair or a current mirror. The KSC1815 or the 2SC1815GR that you are going to find are not going to be good to substitute parts that have hfe larger than 600. Even the 2SC1815BL that i have measured have hfe of 500 at most and you are not going to find them easily. Be aware of many 2sc1815GR thar are counterfeit. They are not good, do not use them. They usually came with the marking perpendicular to the direction of the pins, typically they will read :
C1815 or C1815
GR331 GR133
Other fakes are marked with the letters in the same direction as the pins, and read
C1815
GR 2E
Fakes, do not use.
The original Toshiba parts are noticeably larger than the fakes and have always the markings in the direction of the pins, and the lettering is imprinted with a metalic or greyish epoxy paint. Not laser marked like the fakes. The On semi-Fairchild are laser marked, but their marking is very different from the fakes.
For large gains, there are few transistors that can be used. If you can locate some 2SC2240BL they woould have gains in the 500-550 range and can handle 100mA.
The 2sc1345 is a large gain transistor, I do not know if is a failure prone part. For this large gains, ther is the Toshiba 2SC3112A or KEC KTC3112A.
Here they are 48 cents a piece as of today. The same company has the
2sc1345 for 98 cents a piece. They do not specify the gain rank. But the 2SC3112 are superbeta transistors so their Vbe may be too large or unmatched and i think that they may also oscillate if used as a differential pair.
You may also take a look at these:
2SC1571 (20 cents a piece) or
2SC1570 (1.49 a piece). I have no affiliation with that company but is known here to sell genuine parts. Another one is the NEC 2SC1222 (ECB) (35 cents part as of today) which are high gain, but they were also made by Samsung with pin out EBC which requiere twisting the pins a bit. With this info you should be able to fix you unit.
