I got into the hobby thinking $500 was a reasonable budget for speakers, about the same for an amp, about $250 for a pre and about $350 for a cdp/outboard DAC. Thing is I didn't limit myself to one set of speakers, one amp, and one pre. I bought several of each and had them all at the same time so I could sample many different flavors and pick my favorite(s). At that budget level, around $1500 for a complete system, I configured several very nice sounding systems....nicer than most non-hobbyist (and some hobbyists) ever heard or will ever hear (with an acoustically treated room being a very, very important component of that equation). And this was with separates as I figured out early on there is a (relatively) low performance ceiling with receivers (using a Sansui 8080 db as my yardstick). I've since pushed those numbers up two, even three fold and have added three, maybe four hundred dollars to the budget for proper cables, interconnects, and power cables (used) and it has moved the listening experience to a whole different realm of performance....mind blowing for the uninitiated, actually. The two best performing speakers in my collection, however, are far apart in price. I picked up my Magnepan MG-IIIa's for $400 (but will sink another $400 into upgrading/modifying them) and my Infintiy QLS-1's for over three times that. I have other models that were acquired at price points between the Infinity's and the Maggies, but those two are my standout performers. So, depending on your tastes and expectations, you can get very high levels of performance from you speakers without having to figure any sort of comparative $ to $ ratio against your other gear. I will say this....don't cheap out on a preamp. After the speakers I've found it to have a considerable impact on system performance.
- Michael
