In a current thread, some of our resident Kenwood experts chime in on where to measure the voltage across emitter resistors in order to calculate the current bias... so you can then adjust a trimpot to bring the current bias up or down to factory spec.
I have the "Kenwood Audio Adjustment" PDF, so I can see the example procedure and the specific current my receiver, a KR-6160, is supposed to be adjusted to... but my schematic is a bit different from the example and I have two emitter resistors per channel instead of just one.
I need someone like @hopjohn to explain where I should be measuring and whether I'm aiming for the target current bias from the chart OR half of that.
Screen shots from the Kenwood Audio Adjustment PDF:
The chart in this PDF says the KR-6160 should be adjusted to 20mA.
This is the schematic for the power amp stage in the KR-6160:
So, where should I be putting my voltmeter leads and reading the voltage? Taking just one channel, I think there are two emitter resistors: R171 and R172, each a high wattage 0.47 ohm resistor coming immediately after the final output transistor's emitter.
A. Put the voltmeter leads one on one leg of R171 and the other lead on the other leg of R171 and take a the measurement? If so, am I aiming to adjust this channel's current bias trimpot to reach the 0.47 ohm X 20ma = 9.4mVDC? or just half of that, 4.7mVDC?
B. Put the voltmeter leads one on the leg of R171 closest to Q1 and the other lead on the leg of R172 furthest away from Q2 to take a the measurement? If so, I should adjust this channel's current bias trimpot to reach the 0.47 ohm X 20ma = 9.4mVDC, right?
C. Something else.
Thanks for the help!
C. Something else.
