BLAH BLAH
Yeah but what about my AU-D11?!?!?Loving this discussion... especially the bits about my personal favourite amplifier, the AU-D11 II![]()
Regarding Sansui NRA series - just found some nice photos for AU-A607NRA, including the pcb side for driver boards.
It puzzled me why on the driver board there were 12 transistors instead of 8 as in MR series. At first look I suspected that they added some cascodes, but seeing the pcb side it was obvious that this wasn't the case. But, there is clearly something different to the MR series - in AU-A607NRA what I call VAS transistors (kQ6,7,8,9 in AU-A607MR) are "doubled" - similar with output stages where multiple devices are in parallel.
Otherwise the circuit around the input JFET's is identical with MR series, as I suspected.
Maybe this helps somebody around.
Regards,
Tibi
Greetings, Tibi! I was tempted to purchase at some point the Sansui AU-Alpha 607NRA or the improved Sansui AU-Alpha 607NRA II (this has an extra transformer in the front for the preamp?), but bought something else instead. Now if I want to buy a less expensive Sansui I will focus on AU-607 Mos Premium model because I have noticed it has much better construction and components. The looks are on the side of 607NRA though...
Could you be kind to post those pictures with the inside of 607NRA?
When i adjusted my AU-d707X i used the manuals for the AU-D11 mkIi, and also that for the AU-G90X. But latter on a partial manual for the AU-D907X Decade was kindly made available, so i also looked at that. Member @Ronito6 in this forum translated and posted this procedure for adjusting the AU-D907X which is very useful for x-balaned amplifiers.
Wow! thanks for posting this!. This is the first time i see a service manual for the japanese market version of this series. The document translated by @Ronito6 has been very useful for adjusting my AU-D707X Decade also, which has a small difference in the pinout of the 4 test-points for monitoring the bias setpoint of the 4 output stages.
EDIT:
What I found for the bias test points in the AU-D707X Decade is consistent with page 11 of the recently uploaded AU-D907X Decade schematic: In each of the 3 pin connector, actually the center pin and one of the end pins are used. The guide uploaded in this thread states that the outer pins are used which gives incorrect voltages because one of the outer pins is grounded.
Also, note that the voltage reading corresponding to the bias current recommended in the AU-D907X Decade manual is 47 mV instead of 20mV.
I think the word 'balanced' was just 'marketing speak' for a feature of the power amp topology being promoted at the time. Balanced inputs are provided on professional gear for noise rejection purposes in professional setups where long cables (more liable to pick up noise) are often present.why some x version amps doesn't come with balanced input? A balanced amp without balanced input, why?
