How to connect an iPhone 6 to vintage receiver?
Wouldn't Chromecast for Audio work for this application? I'm asking because it's A) cheap and B) I was looking to gift one to somebody for this exact purpose. iTunes, Podcasts and Spotify on a 64 gig iPhone 5. Cast to a CCA connected to a Yamaha R-S201 driving a pair of AR7s.
ipure 20 docking station... it has its own on board DAC and also does bit perfect file extraction for processing on an outboard DAC when/if you want to upgrade. You may need to purchase a li g htning adapter for the 6s.
These are really good bang for the buck in my opinion.
I have a iPhone 4s and hook it up to my receiver though the tape in. You plug into the
headphone plug on your iPhone to the tape in on your receiver. Works like a charm.
All you need to buy is the cord to run from the phone to the receiver not a lot of money. Hope this helps.
Tazman
If Apple only supported FLAC easily....
Apple is a pain in the ass when it comes to anything cross platform. They don't play well with others.
Lack of FLAC is why I dumped them years ago. That and losing the metadata from my .wav iTubes library in a move.
It depends on what you're doing with FLAC and Apple.
I use FLAC files with my iPhones on a daily basis, but I stream to them from a hard drive plugged into my router. It's a super easy setup.
Putting FLAC files on an iPhone and playing them?Ugh, serious PIA.
I'm looking for something that I can use for streaming music, by pandora or whatever, plus has storage, and capable of playing high res files from its storage(FLAC)...
Squeezebox seemed to be the best option, but have been discontinued for a long time.
Jumped in head first buying the Chromecast for audio for significant other's receiver. Will see how it performs on Christmas Day and beyond.
I use a NuForce Bluetooth receiver for my iPhone > Marantz 2238. Is it hi-rez? No. Is it convenient and good enough? Yes. It can also stream from my laptops.
"Fourthded(??)"
If your using apple products, Airport Express is pretty convenient. Your phone stays with you wherever you are sitting and you have control of the volume, tracks etc. right off the phone. I have had one for 3 years that I couldn't be without now.
You may need to purchase a lightning adapter for the 6s.
Airport Express can be had for under $100, get a Toslink optical cable and a FIIO DAC for $35 ...
If memory serves, the iPure stations have the OLD 30 pin Apple connector -
and iphone 5 and newer models use the Lightening connector -
not sure thats a cheap adapter.
Plus the phone is physically connected to the iDock so unless its beside your chair,
you have to go to it to make changes in song, volume, pause, etc.
Correction - I saw a picture of the iPure 20 and it apparently DOES have a remote ...
^^^^ This. I have the Chromecast Audio unit for $35 and it's great. Decent DAC inside, too. Use a 1/8" headphone jack-to-RCA pair to run from the CCAudio to your receiver AUX, download the Chromecast app... and voila!!
I was hoping that connecting my iPhone 6 to my Harman Kardon 330c was as easy as using an RCA cable to connect the phone into the AUX in the back of the receiver. I hear the music, but I have to crank the volume on the iPhone 6 all the way up and have to crank the volume of the receiver way up as well. Is this what a DAC is for? Is there a solution that doesn't cost so much? I'm just looking to stream an online music service through my home stereo.
Addressing your specific questions, it sounds like something is not set, or working, correctly. I run an iphone, ipad and macbook through the same set up you describe (I think - you're using a 3.5 mini jack to rca?) and all three play normally through several of my vintage and modern receivers when plugged into a line level (aux) jack. I run full volume out of the i-device and adjust volume with the amp or preamp. It sounds like any other line level input, i.e. tuner or cd player.
If you are needing to turn up the amp volume as high as you describe, something must be funky. The volume level imbedded in the streaming service cited above could be it, or have you tried using another line level input, like a tape input?
To the best of my knowledge a DAC is not intended to change the level of the signal; rather, it is designed to decode a digital signal. You are currently taking an analog signal from the iphone (converted from digital by the phone's internal DAC) and running it to the amplifier. You can also take a digital signal from the phone and convert it to analog externally, via the above mentioned docks and cd players for example. Most people here will tell you that the sound quality will be significantly better if you do so, as compared to taking the analog signal from the phone. So that may be something to explore, but it is a different issue from the question you asked.
My profuse apologies if I am stating a bunch of stuff that you already know, and that I misinterpreted your question in too simple a manner. My level of technical expertise is quite low, so it would be an easy error on my part. Further, almost everyone here can tell you much more about how to solve the specific problem. But it seemed like most people were responding with ways to improve the sound quality via digital out/ external dac, and the way I read your question you simply wanted to know why the analog out did not seem to be functioning correctly.
The Chromecast doesn't work with nearly as many apps on iOS. It doesn't work with iTunes, either. The last gen Airport Express ( the one that has everything built into the power connector) can typically be found for less than $50 on Amazon. For iOS, it is currently a much better fit than the Chromecast Audio device.
The way I understand it, the voltage and impedance on my iPhone 6 do match the that of my vintage receiver. As a result, loss of volume and sound quality, so I'll need to put something between the iPhone 6 and the receiver to get the iPhone up to par with the receiver. To quote a part of this article:
This is an Apple iPod dock. It has a ‘line out’ output. (The jack on the left in the above picture). The ‘line out’ will match the exact voltage and impedance of the ‘line in’ on your stereo. It doesn’t matter what volume the iPod is set to. You can leave the audio lead and charger cable plugged into the dock permanently. It will also allow you to control your iPod via any Apple remote control.
My only concern about using Apple specific devices is that there is no guarantee that I'll be using an iPhone in, say, two years. I'm starting to get a little worried about Apple's quality control of late. My iPhone 6 does funky stuff now and again (forget about using it if I'm not on a wifi network or have a 4G LTE connection) and the 2015 MacBook Pro that I use for work is kind of a piece of buggy crap. But hey, if the Apple specific set-up doesn't break the bank, I can just buy a new set-up in a few years if I switch away from Apple. Oh wait, this is Apple. If I get a new iPhone a few years from now, everything will be completely different. Again.
OK, now that I have vented my Apple rantiness for the day, I'm looking at the Airport Express. Does it play music only from iTunes? Or can I use other services like Google Music?
Once again, reading the updates to this thread, I'll have to suggest reconsidering the Teac P650 CD player.
With the exception of wireless, it will do exactly what you want. And unless you get the air port which you've stated your somewhat non-commitment to Apple, wireless streaming over apple products is not the best quality possible.
The Teac, otoh, will connect to other devices as well just by using the standard USB on the front.
