How to deep clean a tube amp
Don,I noticed you didn't put a foam rubber strip across the top of the glass. Is it not needed? I put one there and was wondering if it's stopping the light from coming in.
The strips are about stopping the light from leaking out.
The only light leakage you would get out of the top would be light leakage from the festoons. There's already a gasket surrounding the three sides attached to the sharp edge of the chassis when you pull off the front panel.
The #47 bulbs used in the 500-C/800-C stereo beacons wouldn't shine through the dial glass backing plate.
If the unit is going into a cabinet, the front bezel of the cabinet will contain any light leakage from out of the top.
That said, Iit won't do any harm to wrap the foam strips around all four sides of the dial glass.
The other concern is light leaking out of the gap between knobs and the faceplate. That's the reason for the surround but it wouldn't happen because of light leakage out of the top. On some earlier units, Fisher furnished brown felt surrounds to go behind the knobs. I keep a small stash of those for just-in-case situations.
Hi Don
A few questions.
I´ve planned to start the restoration project on my 400, (improving the fisher 400 thread) but is necessary the clean the chassis, the switches and pots as well (and may be paint the PT and OT´s).
So why you don´t recommend to use the DEOXIT FADERLUBE F5 or F100 in the pots if the manufacturer says that is specifically designed to clean potentiometers (prevent damage in the carbon).
In the other hand the Deoxit D5 is good to clean and remove rust and corrosion, and also to clean the pots???? do you recommend this cleaner??
And finally the isopropyl alcohol can perform the same characteristics as the Deoxit D5?
Thanks in advance!!!!!!
Luis
Luis,
1. Feel free to use faderlube if you want.
I do not choose to use it because it contains a lubricant as well as cleaner and the lubricant will leave residue. That residue may not matter for years, but why chance it? I'm pretty sure the pots were not lubricated when new and it is now approximately 50 years later and most work.
On the opposing side of the issue, the lubrication may be good for a stiff or dry pot(entiometer) and I do have, and I do use, faderlube when I have a stiff or dry pot.
2. Deoxit D5 is too expensive to use as a rust and corrosion remover except in pots and other hard to reach locations that would need it.
The advantage of any of these sprays is that you can reach areas that a swab or a rag will find find it difficult to reach or will never reach.
I have been fortunate enough to find both lubricating and non-lubricating electronics spray cleaners that do not have the name DeOxit and therefore are considerably less expensive to purchase and come in considerably larger cans.
3. On the use of isopropyl alcohol, feel free to try it and let us know how it goes. I do feel that alcohol often has drying properties and that can be good or bad depending on where you use it.
Best Regards,
Don
Thanks again Don, have read this sticky 20 times and still learn something else new.. appreciate your time on this and very helpful
Hi Don
Thanks for your suggestions regarding the cleaners, I´ll let you know about the status but please sorry if I am a stubborn!! I need your advice with this:
Using amonia and warm water (20%/80%) is possible to remove this kind of gray points in the chassis of my amp?, or do you have another procedure??. check the attached pictures.
I don´t want to damage the lettering!!
Once again thank you!!!
Luis
The best cure for those dots on the chassis is a thorough cleaning to diminish them, followed by a coat of wax and then putting the chassis in a cabinet.
If you seek to clean it too deeply, you'll:
1. Expose yourself to the cadmium in the chassis plating.
2. Leave swirlies all over the chassis.
3. Damage the silk screen that identifies the tubes.
The shine won't stay anyway. It will fade with time, regardless of what you do.
The blemishes will never go away completely. Those spots are a reaction to a moist environment. The best fix is a nice cabinet to hide the chassis.
I've had a PM conversation with machineghost, who has a fabulous thread about deep cleaning PCB based gear. We've agreed to cross-reference each other's threads. I'm going to edit my first post and this post to link to his thread.
http://www.audiokarma.org/forums/sho...d.php?t=258899
Thanks machineghost and you've done a job I can only be envious of. Great stuff.
Great thread. The bit about cleaning the tuner glass was particularly inspired and I gave great heed to your advice and all turned out well! THANKS!
Shining up knobs properly
What do you guys use to shine up the brass knob brights? Mine have some pitting or oxidation. Was hoping to get them more even looking.
You can see an example here:
Brasso or Noxon7 on a Terry Cloth. Lay on a flat surface and drop the face of the knob in it. Let sit for about 10 minutes or so, then grab hold and start making figure 8's in the terry cloth. Use a fair amount of pressure. Add more cleaner to keep from drying out as needed. Check surface every couple minutes. When you get the desired effect, rinse in hot water and DAWN. DRY Thoroughly and use a carnauba wax.
This is awesome. I got my work cut out for me on a 500 I just got. I didn't know that this sticky even existed. :thmbsp:
Deoxit substitute
Don,
Would you mind sharing with us the cheaper alternatives to Deoxit that you use? I'm always looking for a better deal :D
Thanks,
Mike
I buy some stuff at an independent local electronics store.
It's a non-lubricating spray . . . which is key when you don't want to leave residue.
It's on this page - look for 409B:
http://www.youdoitelectronics.com/MG/id215.htm
MG Chemicals Electrosolve Contact Cleaner
409B
Contains Isohexanes. A general purpose contact cleaner that quickly penetrates and dissolves most soil types.
Non-conductive
Extremely flammable
Safe on plastics
Fast dry
Medium toxicity
Low cost
Zero residue
Available Sizes
409B-140G 140g (5 oz) Aerosol
409B-340G 340g (12 oz) Aerosol
