I made my own. IMO better than what is sold by VF. https://www.amazon.com/BodyMed-Digi...0074082&sr=8-10&keywords=14X27++heat+pad&th=1 and I use a bunch of 2"clips all around to seal it up.Dave did you purchase the VF pocket? I use that quite effectively. 4-6 hours and I am generally good to good. Have baked em longer if needed.
I have been removing a bend, yes a bend, from an LP for a fellow AKer. It is about 89% better but needle still jumps a bit. This was close to a 40° angle on the bend.
The pad I bought offers much better temp control over the VF pouch. I may have my wife sew three sides closed and make it into a pouch. It cost less than the pouch. My VF used to work better just left in sun but the new top (larger diameter) is BLACK and it gets too hot. Smoothed the grooves right off a couple LPs. I tried leaving outside with a towel over it but that never got warm enough. The oven method is so risky and so hard to do with most ovens really not staying cool enough.
Hard to toss a classic that the reissues all are lowered standards of LP/ pressings/ mastering. No sense working to fix a warped LP easily replaced I guess. The VF does all the work. I just need to load it up and set timer / temp or if not abad warp just leave in VF for a couple weeks.My solution is to toss the warped LP. After all, in this day of high technology why would we want a warped record that was compromised in the first place when it was new and still a virgin?
