dieterboels
Member
Hi,
I have a considerable hum (or buzz?) coming from the SA5300. Somewhere in the 100 Hz range. In both speakers, also in the headphone. The hum is present when no inputs are connected and when volume is down. Doesn't turn up when turning up volume. So all these aspects points at the filter in the power amp failing. I changed all the elco's and the transistors. (Schematic of the power supply stage added)
- What else could it be?
- A bad grounding? How do I easily troubleshoot this?
- What is a way to find the source of this hum?
All help is welcome.
