by the way
I have a late 50's RCA record player that has slight hum in speakers. It gets louder when I touch the tone arm and then totally goes away if I only touch the amplifier and nothing else. The hum does get louder when increasing volume. When I recapped the amp, I did install a three prong power plug. I connected the ground wire from the plug to chassis ground on the amp. Did I create a ground loop and maybe should go back to a two prong plug?
