Audiolab 8200A 60 Watts in 8 ohms ?? in 4 ohms
No phono stage input
http://www.audiolab.co.uk/ProductDetail.aspx?lang=En&Tab2=8200A
Rega Brio R 50 Watts in 8 ohms, and 73 watts in 4 ohms
Has a MM phono stage input
http://www.rega.co.uk/html/Brio-R.htm
Here's two amps in your price range or slightly below.
I'm familiar with both, excellent amps that you should try at your place, or bring your speakers to the shop, although your place is best.
Buying new afford you the chance of making an informed decision.
I understand you already tried the Brio. This one has one option already installed that you might like, a phono stage input, and a very good one at that, while the Audiolab does not include one now with their new model.
You now have the choice between two excellent little integrated amps.
On the vintage side, lots of choices. Pioneer, Sansui, Marantz, Yamaha, Kenwood receivers or integrated amps will also be excellent match for your speakers.
The 40 watts to 80 watts units are usually quite affordable, as opposed to the monster units.
There are to many to name them all, but take a look in here ,
http://www.hifiengine.com/
when you find some, you might want to ask here or read on that site.
The advantage of vintage, you can find excellent units at very affordable prices. The disadvantages, usually, you can't try them, so if you don't like them, you're stuck with them. You could sell them I guess. Also, you always take a chance with used products, no warranty.
