The face plate appears to be a greenish tint towards black. I need to do a small bit of touch up. Anyone have the paint color code? I suppose it could be scanned but if someone already has the actual color code it would be a huge time saver. I just about have the electronics done and the chassis corrosion all buffed out. What a project to say the least.
This one had been ridden hard and put away wet. Buffing out all the corrosion has been by far the hardest part of the restoration. Still need to replace the output tube sockets as someone had jammed the tubes in and mashed the contacts into wads in the bottom. And an endless list of other dipstick moves like no rocker contacts in the phase and output impedance slider switches. Wrong wiring and a number of broken and detached connections. The best though was the hair fine wire wrapped around the blown main fuse. That is always a bad sign…
